The 3D shell, membrane, or rigid elements option allows you to define the *SURFACE card by specifying face identifiers for individual shell, membrane, and rigid elements. In Engineering Solutions graphics, these faces are displayed by special face elements. These face elements have their own normals to define the SPOS and SNEG faces. The face with normals along the underlying element normals define the SPOS faces. In contrast, the face with opposing normals define the SNEG face.
The 3D shell, membrane, or rigid elements option has the following buttons:
Elements |
Opens the Element Selector panel and allows you to pick the underlying 3D shell, membrane, or rigid elements from the graphic area. The selected elements are highlighted and their normals are displayed. The corresponding Reset button resets the selected elements and hides the normals. |
Add |
Adds the selected elements to the current surface and creates special face elements for display. It also checks for duplicate faces and displays a message if any are found. By default, SPOS faces are created. In order to create SNEG faces, activate the Reverse check box and click Add.
Reject |
Rejects the recently added faces. |
