Engineering Solutions
ACIS Metadata Support
The ACIS reader generates the following metadata:
COLOR_RGB
Entities
string
points
lines
surfs
solids
Three RGB values, ranging from 0 to 255, indicating the color of the entity in the CAD model.
Generated when @ColorsAsMetadata = on
DENSITY
Entities
double
solids
The value of the density of a solid.
Generated when @DensityAsMetadata = on
MODELUNIT
Entities
integer
comps
The model units specified in the CAD file.  Values include:
1 = inches
2 = millimeters
4 = feet
5 = miles
6 = meters
7 = kilometers
8 = mils
9 = microns
10 = centimeters
11 = microinches
12 = decimeters
13 = yards
This is always generated.
ORIGINAL_ID
Entities
string
points
lines
surfs
solids
The original CAD entity ID.
Generated when @OriginalIdAsMetadata = on
<name>
Entities
integer
double
string
points
lines
surfs
solids
comps
assems
The <name> field is the ACIS attribute name and the integer/double/string is the value of the ACIS attribute.
Generated when @AttributesAsMetadata = on
See Also:
ACIS Import Options
ACIS Reader Support
CAD Import Options
CAD Metadata Naming
