Engineering Solutions
Area Panel Realization Methods
The following flow chart outlines a four-stage process used to select the best routine for area realizations. This process is very similar to the process related to the spot realization methods. Each test point can be considered as a single spot. The methods are the same and the results look identical.
Note:The quad transition is not yet implemented for area connectors, even though the panel offers these options. Instead of quad transition a simple adjust realization – ensure projection is performed.
connector_realization_area
See Also:
Connector Panels
connectors module
