0-D elements are essentially mesh nodes with an additional value attached to them. The 0-D elements that Engineering Solutions currently supports are masses. Masses have the ability to store one node, a value of mass, and a property reference.
Masses can be created in the Masses panel, and the underlying concept is also the basis for Smooth Particle Hydrodynamcs Mesh.
