Engineering Solutions
Constraints
Constraints
Constraints
Constraints can be used to restrict the movement of nodes during the morphing process. For example in the case of a non-matching interface between two grid regions, it is desired, that the nodes on the interface do not leave the interface plane.
To open this panel click Morphing > Morph Constraints.
cfd_morph_12
See Also:
Quick Morphing Guide for CFD Applications
