Engineering Solutions
Crash Menu Bars
Crash Menu Bars
Crash Menu Bars
The Crash menu bar reflects the sequence of operations that you will most likely be following during the building of the Crash model. Moving from left to right, it starts with Geometry and completes with output request definitions, followed by Morphing options for DOE and optimization. Each menu bar pull-down collects the objects relevant to the function and exposes the objects followed by supported actions in a submenu.
crash_main_menu
See Also:
Crash Application
