Create Part
The Create Part macro enables you to create components on-the-fly. It can be accessed by clicking Create Part on the Utility Menu when the LS-DYNA user profile is loaded.
Type a name for the new component in the Part name field and select a color by clicking the adjacent color icon.
Select a section in the Section field by choosing Create New (create a new section), Same As (create a new section based on an existing section), or Model… (select an existing section) from the selection menu.
Select a material for the component in the Material field by the same method as described above for the Section field.
Click Create>> to either create or create and edit the card.
