Engineering Solutions
SPOINT
SPOINT
SPOINT
The SPOINT macro is used to create SPOINTs.
nas_addspoint
To create SPOINTs:
1.Input nodes in the Node ID(s) window using any the following formats:
2
100 THRU 200
13,24,25
13 14 15
13 THRU 25,30 50
2.Click Add.
The new SPOINTs are created and added to the SPOINTS window.
Note:SPOINTs are treated as NODEs.  Delete them as you would NODEs.
See Also:
Nastran Utility Menu
