Engineering Solutions
Creating Analysis Based Curves
Analysis-based curves are generated from the HyperMesh binary results file.  When you create an analysis curve, you select entities of interest in your model, and then select a data type for the x axis data points and a data type for the y axis data points.  After this information has been supplied, the required data is read from the results file and generates the appropriate curve.  Analysis-based curves are generated in the Results Curves panel.
Return to XY Plotting
