Engineering Solutions
Design Variables
Design Variables
Design Variables
The Design Variables utility is used to review and edit OptiStruct size (including gauge), and shape design variables.
All DESVAR design variables are listed in the table.
design_variables
To edit a design variable:
1.In the table, click the Initial Value, Lower Bound, or Upper Bound field of a design variable.
2.Replace the current value with the desired value.
3.Hit the ENTER key.
The design variable is updated.
To create a design variable:
1.Click entityDesignVariables-24. The following dialog is displayed.
create_design_variables_dialog
2.Fill in the fields as desired.
3.Click Create.
Icon Description
Icon
Create new design variables
refresh-24
Refresh table
table_toggle_icon
Toggles between table edit and table display mode
filter-24
Filter table
fileExport-24
Export table to CSV format
select_all_icon_os2
Select all
select_none_icon_os
Select none
reverse_selection_icon_os
Reverse selection
select_displayed_icon_os
Select displayed
delete_selected_icon_os
Delete selected
See Also:
Utility Menu
