Engineering Solutions
DXF Import Options
DXF Import Options
DXF Import Options
@CleanupTol
Value
double
A negative value (default) means to use the auto cleanup tolerance.  A value greater than the calculated auto cleanup tolerance means to use that specific tolerance.
Refer to the CAD Cleanup Tolerance section.
@ScaleFactor
Value
double
Defines the model scaling factor during import.
Default is 1.0.
See Also:
DXF Metadata Support
DXF Reader Support
CAD Import Options
