Use the EM Lattice Mesh tool to generate an axis-parallel mesh for 2D and 1D geometry input.
1. | To open the EM Lattice Mesh tool, from the menu bar, click Mesh > Create > EM Lattice Mesh. |
2. | Using the Lines and/or Surfaces selector, select 1D and/or 2D entities. |
3. | Specify the Origin, which defines the left most corner of the domain bounding box within which input entities have to be considered. |
4. | Specify the Voxel size, which is the size discretization for Lattice along the x, y, and z axes respectively. |
5. | Specify the Number of Voxels, which defines the right most corner of the domain bounding box. |
The values you enter define the length, breadth, and height of the bounding box in terms of the number of voxels along the axes. The rightmost extreme of the domain bounding box is calculated as:
6. | Click Mesh. The Lattice mesh is created within the specified bounding box. |
