Engineering Solutions
Example of Connecting Assemblies
The projection behavior is illustrated with the following example.
Suppose we have two assemblies [Assem 1 and Assem 2] each having two components [Assem 1 having “Comp 1” and “Comp 2”, Assem 2 contains “Comp 3” and “Comp 4”] in the model file.
Create a connector with the Links as [Assem 1 and Assem 2] and number of layers set to 3.  (This case creates a 3T connection with 2 links.)
During realization the closest found components residing inside the 2 assemblies will be retained as the component links.
Inside each assembly a closest component to the connector is determined to satisfy a 2T connection and for the third layer (3T) the closest component to the connector in either of the assembly links is utilized.
Note:The same projection behavior is used for parts containing components.
Connector_Assembly_Example
