Engineering Solutions
Exporting Decks
Exporting Decks
Exporting Decks
The following LS-DYNA files can be output:
LS-DYNA v971_R7.0, v971_R6.1, v971, v970 and v960 input files in Keyword format.
By default, the LS-DYNA user profile outputs v971_R6.1 .key files.
Two templates are also provided to output the defined curves in the database:
To output curves in Keyword format, use the curves.key template
To output curves in Structured format, use the curves.seq template
See Also:
To Export an FE Model
LS-DYNA Interface Overview
