Engineering Solutions
Fatigue Process
Fatigue Process
Previous topic Next topic Expand/collapse all hidden text
Fatigue Process
Fatigue Process can be accessed from the Tools, when the OptiStruct user profile is loaded. This tool is used to create or open a fatigue analysis setup process. When you select Fatigue Process, two additional options are available: Create New and Load Existing.
hmtoggle_plus1greyCreate New
When you select Create New, the Create New Session dialog appears. From this dialog, you are able to create a new fatigue analysis setup process and save it to your working directory.
create_new_session_dialog
hmtoggle_plus1greyLoad Existing
When you select Load Existing, the Fatigue Process Manager Browser appears. From this browser, you are able to load a fatigue analysis setup process that has been previously saved to a file.
fatigue_process_manager_browser
