The FE configuration file (feconfig.cfg) is used to define custom welds such as ACM (Area Contact Method) and other special types. The weld definition is solver dependant (NASTRAN, LS-DYNA, etc.). The weld definition in the file includes the type of weld to create and the surrounding connector to shells. The specific solver template for the type of weld must be loaded before the welds can be created using a connector entity. When HyperWorks Desktop or HyperMesh launches, it searches for feconfig.cfg in the folllowing locations (listed in search order):
1. | The product installation path |
2. | HW_CONFIG_PATH (a specified environment variable) |
3. | Your home directory (in UNIX, for example) |
4. | The current working directory. |
By default, the feconfig.cfg file from the <install_directory>/hm/bin directory is loaded in each of the panels related to each connector type (such as Spot, Seam, Area, etc). It is not recommended to have more than one config file of the same name, even in different directories, as the results can be unpredictable as to which one will be used by default.
The FE configuration file has a pre-defined format that must be used to define different weld configurations. See FE Configuration Examples for information regarding the format and options for custom weld definition.
The weld definition template is shown below:
CFG <SOLVER> <USER_FE_TYPE> <USER_FE_NAME>
*filter <FILTER_TYPE > [<FILTER_TYPE>]
*style < STYLE_TYPE> <STYLE_NUM>
*head
<HM_FE_CONFIG> <HM_FE_TYPE> <RIGID_FLAG>
*body <BODY_FLAG>
<HM_FE_CONFIG> <HM_FE_TYPE> <LENGTH_LOCATION_FLAG> [<DOFS>]
[<HM_FE_CONFIG> <HM_FE_TYPE> <LENGTH_LOCATION_FLAG> [<DOFS>]]
*post <POST_SCRIPT_NAME>
The template key words and their parameters are defined below.
CFG |
The key word to start a custom weld definition. |
SOLVER |
The solver template for which FE needs to be created. Supported solvers are: Abaqus, Ansys, LS-DYNA, Nastran, OptiStruct, PAM-CRASH, or PAM-CRASH 2G. |
USER_FE_TYPE |
A unique (with respect to a solver) user defined configuration type id. Customer-defined CFGs should use numbers greater than 10,000 to ensure no collisions with future native HM CFGs. |
USER_FE_NAME |
The user-specified name for the FE configuration. The specified name is saved and displayed in the Connector Browser. |
*filter |
This option can be used to allow only the specified connector types to realize the configuration. For example, *FILTER spot seam indicates that this configuration can be realized only by the spot and seam connector types. In addition, this option is used as a filter when displaying FE configurations in the type = field of respective realize panels. *filter lines also set which panel the CFG is visible in. |
CE_TYPE |
The connector type--spot, bolt, seam, area, and so on. |
*style |
This option indicates that the configurations have specific behaviors associated during realization, and that they are native types.
For example, *style bolt 1 indicates that this is a bolt connection of type 1 that creates a specific bolted connection between the parts. |
STYLE_TYPE |
The connector style name, such as "adhesive", "bolt", "acm", "quad", "continuous", etc. |
STYLE_NUM |
The connector style number:
"1" Mesh independent adhesive nodes tie to shells with RBE3/RBE2. "2" Forces shell gap length on. Adhesive (HEXA element) shares nodes with shell at co-incident locations.
"0" normal bolt: "wagon wheels" in the holes. "1" symmetrical spider bolt. "2" unsymmetrical spider bolt: the middle node is biased towards one hole. "3" cylinder bolt: ties together all nodes within virtual cylinder.
"1" The nodes of HEXA element are shared for consecutive layers (> 2T) and the length of HEXA is average of part thickness. "2" The HEXA elements in consecutive layers have unique nodes and the length of HEXA is average of part thickness. "3" The nodes of HEXA element are shared for consecutive layers and the length of HEXA is the gap distance b/w parts. "5" The HEXA nodes are not equivalenced with the shell nodes/washer nodes (if washer present).
"1" Two sets of QUAD4 elements are created, first along projection direction and second at an orientation determined by average part thickness. "2" One set of QUAD4 elements are created at an orientation determined by average part thickness. |
*head |
The string head is required to specify that a rigid is to be created to connect the weld node to the surrounding shell element. *head lines must be followed with at most one HM_FE_CONFIG line. |
HM_FE_CONFIG |
The config for the rigid currently supported. The various types supported are "bar2", "bar3", "equations", "gap", "hex8"(3D), "plot", "mass"(0D), "rigid", "rigidlink", "rbe3", "rod", "spring", "weld", "quad4"(2D seam only), or "penta6"(3D adhesive only). |
HM_FE_TYPE |
A unique (with respect to a solver) user defined configuration type id defined in the solver template. |
RIGID_FLAG |
Defines the number and arrangement of rigids.
DOFS |
The degrees of freedom of the rigid (1-6). This parameter is optional. |
*body |
The string body is required to specify that a weld is to be created to connect the link entities added to the connector. *body lines may be followed by one or more HM_FE_CONFIG lines |
BODY_FLAG |
The body flag is used to calculate the length of the weld. If the body flag = 0, the length is calculated based on the distance between the connecting layers (link entities). If the body flag = 1, the length is calculated based on the average thickness of the connecting layers (link entities). |
HM_FE_CONFIG |
HM_FE_TYPE |
The solver defined type for the HyperMesh config. For example, CBUSH is of config spring and type 6. The type number is defined in respective solver templates and differs, based on the solver. |
LENGTH_LOCATION_ |
0D Element Details: supported values = 0, 1, or 2 "0" places the 0D element along the proposed 1D element path. If this 0D element is the only config given in the *body, then it is placed at the center of the proposed 1D element path. "1" has the same behavior as "0" except only a single 0D element is created even if multiple bodies are created (as happens in >2T welds). "2" places the 0D element at the connector location.
1D Element Details: supported values = from 0 to 1 (inclusive), 2, 3 "0" forces zero length welds. >"0" but <"1" (such as 0.33 or 0.5) denote a percentage of the distance between shells the length of a given weld should be. To create series welds, all the PERCENT_LENGTH_FLAG variables for a given *body must add up less than or equal to 1.0. "1" forces each body weld to have a length equal to the distance between the shells (which can be used for parallel welds). "2" places the 1D element at the connector location (with both nodes coincident). "3" places multiple (thickness-1) 1D elements at the connector location connected end-to-end (with all nodes coincident).
3D Element Details: supported values = 0 and 1 "0" forces a floating hexa element to have a length equal to half the distance specified by the BODY_FLAG. "1" forces the hexa element's length to be equal to the full distance specified by the BODY_FLAG. |
DOFS |
The degrees of freedom (1-6) of the rigid. This parameter is optional. |
*post |
*post lines are optional, but if specified, they must be followed by the name (excluding path) of a valid TCL script with a .tcl extension. Engineering Solutions searches for the TLC script in the locations and order specified below:
This post script will be automatically executed post FE realization, and can be used to edit weld properties, attributes, and other solver specific details. |
• | Each solver will have a specific definition so the same user-defined types can be repeated for each solver. |
• | The head and the body definition must begin with a "*" to define rigid and weld definitions. |
• | Multiple solid element combinations are not currently supported. Therefore, an ACM can have only one hexa weld element specified in the definition. |
• | 1D and 3D element combinations are not supported. |
• | The total length of series welds cannot exceed 1.0 (100 percent). Hence there cannot be three welds specified in series having a length factor of 0.5 (50 percent) each. |
• | Series and parallel weld element combinations are not supported. |
• | Series welds are not supported where the link entities are coincident. Series welds are not created when the distance between the connecting link entities is zero. |
• | User comments should start with a hash character "#". |
See Also:
