Engineering Solutions
Bounding Faces
Bounding Faces
Bounding Faces
A bounding face is a surface that defines the outer boundary of a single solid.
Bounding faces are shaded green by default.
A bounding face is unique and is not shared with any other solid.  A single solid volume is defined entirely by bounding faces.
See Also:
Solids
Geometry Terminology
