»Click here to display Table of Contents« Geometry > Terminology:
This setting is used to determine when model geometry should have a new vertex added (creating two surfaces from one) or removed (merging two surfaces into one). The angle is measured between the positive normal faces of adjacent geometric entities.
Geometry Terminology
