Engineering Solutions
Surfaces
Surfaces
Surfaces
A surface represents the geometry associated with a physical part.  A surface is a two-dimensional geometric entity that may be used in automatic mesh generation.
Its color is determined by the component collector to which it belongs.
A surface is comprised of one or more faces.  Each face contains a mathematical surface and edges to trim the surface, if required.   When a surface has several faces, all of the faces are maintained as a single surface entity.  Operations performed on the surface affect all the faces that comprise the surface.  In general, Engineering Solutions automatically uses the appropriate number of and type of surface faces to represent the geometry.
The perimeter of a surface is defined by edges.  There are four types of surface edges:
Free edges
Shared edges
Suppressed edges
Non-manifold edges
Surface edges are different from lines and are sometimes handled differently for certain operations.
The connectivity of surface edges constitutes the geometric topology.
See Also:
Faces
Fixed Points
Free Edges
Shared Edges
Suppressed Edges
Non-manifold Edges
Geometry Terminology
