Engineering Solutions
Importing and Exporting HyperBeam Comments
Importing
On import of a FEA model, beamsections are automatically created for all bar, beam, and rod properties that do not already have beamsections defined. These beam sections automatically populate bar, beam, and rod property cards and the cross-section should be edited with HyperBeam. 3D visualization of beams in HyperMesh is only made possible through HyperBeam beamsections and their association to properties.
To import a FEA model without automatically creating beamsections for each 1D property, use the custom import feature with beamsections and beamsection collectors unchecked. The section information on the actual property cards will remain intact, but the geometric and section calculation data will be missing.
hbeam_import_comments
Exporting
Exporting a FEA deck in HyperMesh operates in a similar fashion. HyperBeam comments are written out by default (as are all HyperMesh comments). In order to suppress HyperBeam comments from being exported, you must use the Custom export feature, or the Solver option to turn off all comments. Beamsections are stored as HyperBeam comments in an exported deck.
hbeam_export_comments
