Engineering Solutions
JT Import Options
JT Import Options
JT Import Options
The JT reader uses the jt_reader.ini file with the following available options:
@ApplyLayerFilters
Value
string
Import only the specified layer filters.
The string should be in the form of "%filter1%filter2%filter3". The filter names are listed, separated by a character that you choose, and inserted as the first element of the string. The example uses '%' as a separator. You can choose another character as a separator, in case one of the listed attribute names contains '%'. HyperMesh will recognize it as it is the first character of the string.  A special value of DEFAULT can be used to indicate the default layer filter.
@AttributesAsMetadata
Value
on
Import all generic attributes (global and related to single entities) as metadata.
<name>
off
Do not import generic attributes.
part
Import just the global attributes (the attributes related to the part as a whole) as metadata.
<name>
entity
Import just the entity attributes (the attributes related to single entities) as metadata.
<name>
%attribute1%attribute2%attribute3
Import specified generic attributes as metadata.
The attribute names are listed, separated by a character that you choose, and inserted as the first element of the string. The example uses '%' as a separator. You can choose another character as a separator, in case one of the listed attribute names contains '%'. HyperMesh will recognize it as it is the first character of the string.
<name>
@BrepAndTessLoadOption
Value
Import B-rep or tessellation, with B-rep given preference. If B-rep is present, tessellation is not imported (default).
1
Import both the B-rep and the tessellation.
2
Import only the B-rep. If B-rep is not present, nothing is imported.
3
Import only the tessellation. If tessellation is not present, nothing is imported.
@CleanupTol
Value
double
A negative value (default) means to use the auto cleanup tolerance.  A value greater than the calculated auto cleanup tolerance means to use that specific tolerance.
Refer to the CAD Cleanup Tolerance section.
@ColorsAsMetadata
Value
on
Read color attributes of geometric entities as metadata.
COLOR_RGB
off
Do not read color attributes (default).
@DoNotMergeEdges
Value
on
Preserve the original geometry edges, instead of merging them together during the import cleanup phase.
off
Merge edges together during the import cleanup phase (default).
@FilterByJTOpenParts
Value
string
Import only the specified parts.
The string should be in the form of "%part1%part2%part3". The part names are listed, separated by a character that you choose, and inserted as the first element of the string. The example uses '%' as a separator. You can choose another character as a separator, in case one of the listed attribute names contains '%'. Engineering Solutions will recognize it as it is the first character of the string.
@ImportForVisualizationOnly
Value
on
Import the model for visualization purposes only.
This skips many of the import steps (cleanup, stitching, solid creation, and so on) to provide a faster import. The resulting model may not be suitable for other uses.
off
Import the model in the normal fashion (default).
@ImportFreeCurves
Value
on
Import free curves (wireframe entities) into the model (default).
off
Do not import free curves.
@ImportFreePoints
Value
on
Import free points into the model (default).
off
Do not import free points.
@MaterialName
Value
string
Name of the CAD attribute containing the material name info of the current part. Default is "P_MAT"; meaningful only if @AttributesAsMetadata = "part". It only generates temporary data used by the ExtAPI cadassm tool.
@MetadataPrefix
Value
string
The string is prefixed to all metadata names. No prefix is used by default.
See CAD Metadata Naming for more details.
@PartNumber
Value
string
Name of the CAD attribute containing the part number info of the current part. Default is "DB_PART_NO"; meaningful only if @AttributesAsMetadata = "part". It only generates temporary data used by the ExtAPI cadassm tool.
@SkipCreationOfSolid
Value
on
Read surfaces, but do not create solid entities.
off
Create solid entities (default).
@SplitPeriodicFaces
Value
on
Split periodic surfaces to improve the quality and robustness of the import (default).
off
Import periodic surfaces as a single surface with a seam edge.
@TagsAsMetadata
Value
on
Create entity name as metadata (default).
TAG
FromBody
Take entity from its parent body and create it as metadata.
TAG
off
Do not read tags.
@ThicknessName
Value
string
Name of the CAD attribute containing the thickness info of the current part. Default is "P_GAUGE"; meaningful only if @AttributesAsMetadata = "part". It only generates temporary data used by the ExtAPI cadassm tool.
@UID
Value
string
Name of the CAD attribute containing the UID info of the current part.
Default is "UID"; meaningful only if @AttributesAsMetadata = "part". It only generates temporary data used by the ExtAPI cadassm tool.
See Also:
JT Metadata Support
JT Reader Support
CAD Import Options
