Engineering Solutions
JT Writer Support
JT Writer Support
JT Writer Support
The following entities are supported by the JT writer:
Point
Line
Surface
Solid
Elements are exported as tessellations as follows:
­tria3 elements
­quad4 elements, each split into two triangles
­tetra4 element faces
­penta6 element faces, with each quad face split into two triangles
­hex8 element faces, with each face split into two triangles
