In the Manage Model section of the Drop Test Manager, the Import/Create task allows you to choose whether or not the fluid inclusion is needed for the drop test simulation.
The Import tab allows you to select a HyperMesh supported format and import the model. During import, the utility runs a generic geometry cleanup on the CAD formats.
Clicking Mesh opens the Automesh panel, where you can mesh the surfaces.
