Engineering Solutions
Local Display Controls
These controls are located within the tree list, and each affects the specific entity that it appears beside.
Entity Display Icons
You can display or hide entities by toggling the corresponding icon that is located on the left-hand side of the entities name. The following rules apply:
A bold icon next to an entity (components, multibodies, load collector, and so on) represents that the entity is currently displayed; a dimmed icon next to an unchecked entity represents that the entity is turned off from display.
Assemblies containing components or multibodies are considered displayed only when all of the contents are displayed.
Activating an assembly’s display control icon displays all of its contents.
Activating an assembly’s display control icon displays all its components and multibodies.
Deactivating the display control icon check box for an assembly hides all of its components and multibodies.
Deactivating the display control icon for an item hides all of its parent assemblies.
Deactivating the display control icon for an item does not affect the state of its parent assembly.
An empty assembly never displays.
Colors
Assemblies, beam section collectors, blocks, components, contact surfaces, curves, groups, load collectors, materials, properties, shapes, system collectors, tags, titles, and vector collectors can all be colored individually. In the Model browser, the palette-24 column displays each entity’s assigned color. To change an entity’s color, click its color icon and select a new color from the palette.
Display Mode
Components have several display states, based on a combination of their elements and their geometry. In the Model browser, the visualizationElementsShaded-24 column displays the display mode assigned to each component, assembly, or load collector. To change the display state, click the entities display mode icon and then select a new style. Depending on which option you select, the entity displays differently:
FE Styles
Icon
visualizationElementsWireframeSkinOnly-24
Wireframe mesh.
Shaded elements (no mesh).
visualizationElementsShadedWithMesh-24
Shaded elements with mesh lines.
visualizationElementsShadedWithFeatures-24
Shaded elements with feature lines (no mesh)
visualizationElementsTransparent-24
Transparent shaded elements without mesh.
Geometry Styles
Icon
visualizationGeometryWireframe-24
Wireframe geometry.
visualizationGeometryWireframeWithSurfaceLines-24
Wireframe geometry with surface lines
visualizationGeometryShaded-24
Shaded geometry
visualizationGeometryShadedWithEdges-24
Shaded geometry with feature lines
