Engineering Solutions
Modeling Methodologies
Methodology
Trimmed Body
Single file vehicle
Multi-include vehicle
True full-vehicle
Features
Trimmed body
Some suspension FE
Keep subsystem FE in its own include
An object-based assembly environment
Test based loads on body
Some PT FE
Assemble the right includes to form vehicle model
Seamlessly manage multiple representation
Test based PT and suspension
Typically do not include tire or driveline
Only a crude assembly definition exists
Seamlessly manage multiple connection states
Seamlessly manage ID conflicts
Functionality to create reduced representations
Manage loadcase
Manage hardware and analysis configuration
Manage job submission and job history
Advantages
Able to iterate on trimmed body
Able to iterate on suspension and PT somewhat
Able to iterate on all details of a full vehicle
Subsystem handling is somewhat modularized
Subsystem handling is fully modularized
Can easily mix detailed and reduced representations
Can quickly customize model setting based on loadcase needs
Can quickly review and rerun past analysis
Disadvantages
Cannot iterate on suspension and PT changes
Very difficult to connect subsystems given the details
Difficult to manage ID conflicts between subsystems
Have to keep one model for each loadcase
Difficult to manage conflicts between detailed FE and reduced models
Very difficult to update or tune subsystem models
Difficult to check for errors
See Also:
NVH Application
