Engineering Solutions
Organize Xlinks Macro
The XLINK Organizer macro can be used to move and arrange existing LINK type elements (PLINK, ELINK, LLINK, SLINK) to existing components.
The macro contains the following options:
Option
Select element:
Select the element type you want to work with.
Prefix:
Filter the element results by the text you type in the adjacent text box. Click Set to run the filter.
The macro contains the following buttons:
Button
Action
eye_icon
Makes only the selected elements visible in the graphics display.
comp_icon
Select a component/part to which the selected elements will be added.
fileImport-24
Import a component from a PAM-CRASH 2G input file.
To move an XLINK element to a component:
1.Select the type of link element from the Select element field.
The list of elements of that link type are listed in the table along with the parts with which they are associated.
2.Click the component button to select a component to which you want to add the selected elements.
3.Click Apply.
The selected elements are added to the selected component.
See Also:
Tool Macro Menu
