Engineering Solutions
Parasolid Export Options
The Parasolid reader uses the parasolid_writer.ini file with the following available options:
@AllowDisjointShells
Value
on
Store non-manifold geometry in one disjoint feature.
off
Split and store non-manifold geometries as separate joint shell features (default).
@AssemblyMode
Value
flatten
Write entities in all components into a single component.
hierarchy
Single level assembly with each component as a child (default).
@Export
Value
all
Export all geometry (default).
displayed
Export displayed geometry only.
@GeometryMode
Value
Standard
Write CAD geometry with standard types such as cylinder, cone, circle, and so on (default).
BSpline
Convert all surface geometry data into NURBS. This option may increase the output file size and be time consuming depending on the actual geometry.
@MetadataPrefixFilter
Value
string
The prefix to use to find metadata to export. Only metadata with the specified prefix is exported. Any metadata without this prefix is not exported.  Default is empty, meaning all metadata will be exported.
@OptimizeForCAD
Value
on
Fix gaps between stitched edges and vertices to make the actual geometry of the surfaces consistent with the model topology before export, and check the topology of the model for gaps that are larger than a given tolerance between shared, non-manifold, or suppressed edges. If the gap is found to be bigger than the tolerance, the surface and edge geometries are morphed parametrically and in 3D, if necessary, to make the gap smaller than the tolerance. In addition, non-essential degenerate edges are removed.  This also modifies the geometry within HyperMesh (default).
off
Do not perform the optimization steps.
@RemoveMetadataPrefix
Value
on
Remove the metadata prefix for export.
Meaningful only if @MetadataPrefixFilter is enabled and non-empty.
off
Do not remove the metadata prefix for export (default).
@TopologyMode
Value
Solid/Shell
Export topology data similar to HyperMesh topology data, keeping the distinction between solids and shells (default).
Surface
Export each surface, including solid faces, as a single surfaces, effectively neglecting connectivity.
@Units
Value
Microns
Millimeters
Centimeters
Meters
Kilometers
Microinches
Inches
Feet
The unit system to use for export.  Parasolid stores data in millimeters only.  This value is taken as the existing unit system and all values are converted from this system into millimeters.
@Version
Value
string
The Parasolid version to use for export.  Valid versions are 27.0 (default), 26.1, 26.0, 25.1, 25.0, 24.0, 23.0, 22.0 or 21.0.
@WriteColorFrom
Value
string
Specify colors for the geometrical entities during export.  Colors are supported at the component level only, whereas individual entity colors (points, lines, surfaces, solids) are not supported.
Valid values are Component (default) and Metadata.
@WriteMetaDataAsColor
Value
string
Specifies the metadata to use for coloring entities.
Default is COLOR_RGB.
Meaningful only if @WriteColorFrom = "Metadata".
@WriteMetaDataAsName
Value
string
Specifies the metadata to use for naming entities.
Default is TAG.
Meaningful only if @WriteNameFrom = "Metadata".
@WriteNameFrom
Value
string
Specify names for the geometrical entities during export. Names are supported at the component level only, whereas individual entity names (points, lines, surfaces, solids) are not supported.
Valid values are Component and Metadata (default).
See Also:
Parasolid Writer Support
CAD Export Options
