Engineering Solutions
Pro E Import Options
The Pro E reader uses the ct_reader.ini file with the following available options:
@AttributesAsMetadata
Value
on
Import all generic attributes (global and related to single entities) as metadata.
<name>
off
Do not import generic attributes.
part
Import just the global attributes (the attributes related to the part as a whole) as metadata.
<name>
entity
Import just the entity attributes (the attributes related to single entities) as metadata.
<name>
%attribute1%attribute2%attribute3
Import specified generic attributes as metadata.
The attribute names are listed, separated by a character that you choose, and inserted as the first element of the string. The example uses '%' as a separator. You can choose another character as a separator, in case one of the listed attribute names contains '%'. Engineering Solutions will recognize it as it is the first character of the string.
<name>
@CleanupTol
Value
double
A negative value (default) means to use the auto cleanup tolerance.  A value greater than the calculated auto cleanup tolerance means to use that specific tolerance.
Refer to the CAD Cleanup Tolerance section.
@ColorsAsMetadata
Value
on
Read color attributes of geometric entities as metadata.
COLOR_RGB
off
Do not read color attributes (default).
@DensityAsMetadata
Value
on
Read density value as metadata (default).
DENSITY
off
Do not read density value.
@DoNotMergeEdges
Value
on
Preserve the original geometry edges, instead of merging them together during the import cleanup phase.
off
Merge edges together during the import cleanup phase (default).
@FullNameAsMetadata
Value
on
Generate the full CAD name, as retrieved from the CAD part, as metadata. This consists of assembly name/part name/feature name/entity name.
FULL_IDENTIFIER
off
Do not generate full name metadata (default).
@ImportBlanked
Value
on
Import entities that are hidden, blanked or no show.
off
Do not import entities that are hidden, blanked or no show (default).
@ImportForVisualizationOnly
Value
on
Import the model for visualization purposes only.
This skips many of the import steps (cleanup, stitching, solid creation, and so on) to provide a faster import. The resulting model may not be suitable for other uses.
off
Import the model in the normal fashion (default).
@ImportFreeCurves
Value
on
Import free curves (wireframe entities) into the model (default).
off
Do not import free curves.
@ImportFreePoints
Value
on
Import free points into the model (default).
off
Do not import free points.
@MaterialName
Value
string
Name of the CAD attribute containing the material name info of the current part. Default is "Material"; meaningful only if @AttributesAsMetadata = "part". It only generates temporary data used by the ExtAPI cadassm tool.
@MetadataPrefix
Value
string
The string is prefixed to all metadata names. No prefix is used by default.
See CAD Metadata Naming for more details.
@OriginalIdAsMetadata
Value
on
Import original CAD entity IDs as metadata.
ORIGINAL_ID
off
Do not import original CAD entity IDs as metadata (default).
@PartNumber
Value
string
Name of the CAD attribute containing the part number info of the current part. Default is "PartNumber"; meaningful only if @AttributesAsMetadata = "part". It only generates temporary data used by the ExtAPI cadassm tool.
@ScaleFactor
Value
double
Defines the model scaling factor during import.
Default is 1.0.
@ShrinkSurfaces
Value
on
For trimmed surfaces, shrink the corresponding base surfaces to only enclose the extents of the external trimming contour, plus a narrow frame.
off
Do not modify the base surfaces (default).
@SkipCreationOfSolid
Value
on
Read surfaces, but do not create solid entities.
off
Create solid entities (default).
@SplitComponentsByBody
Value
on
Create one HM component per third party body. There might be one or more third party bodies per third party component. This option cannot be used when @ReadCompositeData is enabled, or in conjunction with @SplitComponentsByPart.
off
Do not consider the division of third party components into third party bodies while creating HM components (default).
@StitchingAcrossBodies
Value
on
Stitch surfaces belonging to different components.
off
Do not stitch surfaces belonging to different components (default).
@TagsAsMetadata
Value
on
Create entity name as metadata (default).
TAG
FromBody
Take entity from its parent body and create it as metadata.
TAG
off
Do not read tags.
@ThicknessName
Value
string
Name of the CAD attribute containing the thickness info of the current part. Default is "Thickness"; meaningful only if @AttributesAsMetadata = "part". It only generates temporary data used by the ExtAPI cadassm tool.
@UID
Value
string
Name of the CAD attribute containing the UID info of the current part.
Default is "UID"; meaningful only if @AttributesAsMetadata = "part". It only generates temporary data used by the ExtAPI cadassm tool.
See Also:
Pro E Metadata Support
Pro E Reader Support
CAD Import Options
