Engineering Solutions
Quality Index Calculations
The Quality Index value is a function of twelve criteria with user-defined weight factors. Each criterion has five rating levels. Engineering Solutions assigns a penalty value to each element according to its rating for individual criteria. The elements that fail a criterion are assigned a penalty of 1.0 to 10.0 as a linear function of how far the element is from satisfying the criterion. The elements that pass a criterion are assigned a penalty value of 0.0 to 1.0 for that criterion. The quality index (Q.I.) is a function of individual criteria penalty values. Each element is assigned the corresponding element Q.I. color.
element Q.I.
(weighted average of penalties that pass) +
(weighted sum of penalties that fail)
criteria Q.I.
(weighted average of penalties of elements that pass) +
(weighted sum of penalties of elements that fail)
compound Q.I.
(weighted average of criteria Q.I. that pass) +
(weighted sum of criteria Q.I. that fail)
All of this means that higher compound Q.I. values indicate worse quality.
Each criterion has five levels as described below. The elements are assigned a penalty depending on where they fall in these levels:
Ideal
This is the absolute best/ideal value that an element can achieve. For example, an ideal element would have an aspect ratio of 1.0, warpage of 0.0, jacobian of 1.0, and so on.  Some criteria may not have an ideal, for example the ideal minimum element size is the same as average element size. Similarly, for simulations that require all triangular mesh, "% of trias" is not applicable. Thus the ideal "% of trias" depends on the analysis type, and should be set by you. Elements that fall in this level are drawn in their default color (not highlighted).  Ideal elements have no penalty assigned to them.
Good
This level is slightly worse than ideal, but is still considered good for the required analysis.  All elements whose criteria are equal to or better than this level are considered good and no penalty is assigned to them. You set all the good level thresholds. Elements that fall in this level (between good and warn) are drawn in their default color (not highlighted). The elements that fall between good and warn are assigned a penalty between 0-0.79.
Warn
This is an intermediate level between good and fail.  This level is used to highlight the elements that have not failed the criteria, but are close to it.  HyperMesh sets these values at 80% between good and fail levels.  The elements that are in this level (that is, falling between warn and fail) are drawn in cyan by default and are assigned a penalty value between 0.8 – 0.99.
Fail
This level determines the elements that are considered to be unacceptable for analysis, thus failed.  It is recommended that you fix these elements before performing the analysis.  You can specify the fail levels.  All the elements that fail are given a penalty greater than 1.0.  The penalty value is calculated depending on the severity of the failure.  The elements that have failed (between fail and worst) are drawn in yellow by default and are given a penalty value between 1.0-10.0.  Therefore, elements that passed all criteria have a penalty less than 1.0.
Worst
This level allows you to highlight elements that failed the criteria by a large margin, and which require immediate attention.  The worst levels are set by Engineering Solutions as a factor of good and fail values.  The elements that fall in and beyond this worst level are drawn in red and given a flat penalty value of 10.0.
quality_index1
In addition to these levels, you can also turn on/off individual criteria according to your analysis requirements.  You can also set different weights for individual criteria.  For example, if jacobian is relatively more important than warpage, you can choose to set jacobian comp weight to 2.0.  The Comp QI calculated will then give jacobian twice the weight as the remaining criteria.
