You can use the Conversion tool to convert a RADIOSS file to a PAM-CRASH 2G file.
1. | After loading the RADIOSS user profile and importing a RADIOSS model, run the conversion macro by clicking Tools > Conversion > PAMCRASH. The Conversion tab opens. |
2. | In the Destination template field, select the destination solver version. |
3. | Click Convert to start the conversion. After conversion, the selected version of the PAM-CRASH 2G user profile is automatically loaded. |
4. | Review and export the deck using the PAM-CRASH 2G user profile. |
Some of the keywords in the RADIOSS deck are converted to the PAM-CRASH 2G deck as per the following table:
Engineering Solutions configuration, RADIOSS type
PAM-CRASH 2G type
TRUSS
BAR
BEAM
BEAM
SPRING
SPRING
SPRING+PROP/SPR_BEAM (TYPE 13)
SPRBM
SH3N
SHELL
SHELL
SHELL
BRICK
SOLID
TETRA44
TETRA44
ADMAS
MASS
SPRING+INTER/TYPE2
PLINK
SPRING+PROP/KJOINT(TYPE33)
KJOIN
RBODY
RBODY
PAM-CRASH 2G type
INIVEL
INVEL
BCS
BOUNC
CLOAD
CONLO
PAM-CRASH 2G type
FRAME/FIX
FRAME
SKEW/MOV
FRAME
SKEW/FIX
FRAME
PAM-CRASH 2G type
M1_ELASTIC
MAT_1D TYPE 201, MAT_2D TYPE 101
/PROP/SPRING
MAT_1D TYPE 220
/PROP/SPR_BEAM
MAT_1D TYPE 223
M0_VOID
MAT_2D TYPE 100
M36_PLAS_TAB
MAT_2D TYPE 102/103
M44_COWPER
MAT_2D TYPE 102/103
M2_PLAS_JOHNS
MAT_2D TYPE 102/103
PAM-CRASH 2G type
PROP/BEAM
PART, TYPE= BEAM
PROP/KJOINT
PART, TYPE = KJOIN
PROP/SHELL
PART, TYPE = SHELL
PROP/SOLID
PART, TYPE = SOLID
PROP/SPRING
PART, TYPE = SPRING
PROP/SPR_BEAM
PART, TYPE = SPRING
PROP/SPR_GENE
PART, TYPE = SPRING
PROP/TRUSS
PART, TYPE = BAR
PAM-CRASH 2G type
FUNCT
FUNCT
PAM-CRASH 2G type
TITLE
TITLE
OCTRL/
DSYOUPUT
/ANIM/DT
THPOUTPUT
/TFILE
PAM-CRASH 2G type
PART
PART
PAM-CRASH 2G type
CNTAC36
INTER/TYPE7
PAM-CRASH 2G type
RWALL
RWALL
PAM-CRASH 2G type
TH/SPRING
THELE
TH/NODE
THNODE
TH/FRAME
THLOC
PAM-CRASH 2G type
SECT
SECFO
PAM-CRASH 2G type
GRNOD/NODE
GROUP
GRNOD/GENE
GROUP
GRNOD/SUBSET
GROUP
GRNOD/PART
GROUP
GRNOD/MAT
GROUP
GRNOD/PROP
GROUP
GRNOD/GRNOD
GROUP
GRNOD/SURF
GROUP
GRNOD/GRSHEL
GROUP
GRNOD/GRBRIC
GROUP
GRNOD/GRSPRI
GROUP
GRNOD/GRSH3N
GROUP
GRNOD/GRTRUS
GROUP
GRNOD/GRBEAM
GROUP
GENOD/NODENS
GROUP
GRNOD/FORMULA
GROUP
PAM-CRASH 2G type
BAGIN
MONVOL
The attributes converted in each KEYWORD is explained in the Conversion dialog. Each keyword is associated with a color to distinguish it better.
• | Green: All the attributes of the KEYWORD are converted to equivalent in PAM-CRASH 2G. |
• | Orange: Only some of the attributes of the KEYWORD are converted to equivalent in PAM-CRASH 2G. |
• | Red: None of the attributes of the KEYWORD are converted to equivalent in PAM-CRASH 2G. Basically conversion of this keyword is not supported by the conversion tool. |
See Also:
Tools Menu
Crash Application
