Engineering Solutions
Response Point Manager
The Response Point Manager is invoked by clicking the responsePoint-24 icon, which opens the Define Response dialog.
This tool allows you to create defined response points that will be automatically used in setting up output requests in NVH analysis. To add response points, click the add-24 icon, which opens the Select Tagpoint Metawidget dialog, and select a module with tagpoints in it. To delete a response point, highlight the row corresponding to the response point, and then click the delete-24 icon. When completed, click Update to save changes made to response points or click Cancel to discard changes made since the last update, and exit the dialog.
define_response_result_dialog
See Also:
NVH Application
