The following entities are supported by the STEP writer:
• | Point |
• | Line |
• | Surface |
• | Solid |
The following entities are not supported by the STEP writer:
• | Axis system |
• | Fixed points. In order to export fixed points, it is necessary to convert them to free points. Then, after import, those free points must be projected onto the appropriate lines or surfaces in order to generate fixed points with the proper association. |
• | Vector |
