Engineering Solutions
Stop Angle Implementation
Normally, the stop angles are given by load curves.  The second and last curve points are used to determine the stop angle.  If a load curve has less than four entries, the first and the last entries are used.  You can find the implementation of the stop angle in the HM_JOINT_INFO function in the function template of the PAM-CRASH 2G Interface.  If load curves are not defined for a joint, default values for stop angles ( -270°C to +270°C ) will be displayed in the Dummy Positioning panel.
See Also:
Dummy PositioningTool Start Macro
PAM-CRASH 2G Materials Supported for Dummy Positioning
Update Initial Rotation Angle in the JOINT Card
