Engineering Solutions
Surface Generation
Surface Generation
Surface Generation
A surface description of the morphed grid can be derived by using the fe to surf functionality. The geometry can then be exported in IGES format.
Open this panel by clicking Geometry > Create > Surfaces > From FE.
suface_generation_panel
surface_generation_example
See Also:
Quick Morphing Guide for CFD Applications
