Engineering Solutions
Secondary Menu
Secondary Menu
Secondary Menu
The secondary menu is a list of panels that can be accessed by using the function keys F1 through F12, or in combination with the SHIFT or CTRL keys. The secondary menu allows you to use panels that add information necessary to complete the currently active panel.
When you use the secondary menu, it interrupts the active panel and allows you to perform a function in the secondary panel, and upon completion, to continue using the initial panel. Entities selected while in the secondary panel are still selected when you return to the initial panel.
The default secondary panels are as follows:
Key
Function key only
plus SHIFT key
plus CTRL key
F1
hidden line
color
print slide
F2
delete
temp nodes
slide file
F3
replace
edges
print eps
F4
distance
translate
create eps file
F5
mask
find
print b/w eps
F6
element edit
split
create JPEG file
F7
align node
project
Full Screen mode
F8
create node
node edit
F9
line edit
surf edit
F10
check element
normals
F11
geometry quick edit
organize
F12
automesh
smooth
Note:Function keys may be reassigned to different panels by using the Build Menu panel.
See Also:
Keyboard
