Engineering Solutions
UG Environment Variables
Since the UG reader needs to use the UGOpen library during the run time, it requires that a valid UG installation and UG license be present and available to the user with the assemblies, gateway and solid_modeling modules.
The following environment variables must be set prior to starting:
WINDOWS
UGII_BASE_DIR
This must point to the UG installation directory1.
UGII_ROOT_DIR
This must point to the UG installation UGII directory1.
PATH
This must include the %UGII_BASE_DIR%\UGII\ directory2.
SPLM_LICENSE_SERVER
UGS_LICENSE_SERVER
This must point to the UG license server3.
UGS_LICENSE_BUNDLE
This must specify the UG license bundle.
Example: UG installation located at C:\Program Files\Siemens\NX 9.0
UGII_BASE_DIR: C:\Program Files\Siemens\NX 9.0
UGII_ROOT_DIR: %UGII_BASE_DIR%\UGII\
PATH: %UGII_BASE_DIR%\UGII\
SPLM_LICENSE_SERVER: 28000@licsrv
UGS_LICENSE_BUNDLE: NXPTNR100
LINUX
UGII_BASE_DIR
UGII_ROOT_DIR
This must point to the UG installation bin directory1.
SPLM_LICENSE_SERVER
UGS_LICENSE_SERVER
UGS_LICENSE_BUNDLE
Example:  UG installation located at /soft/usr/ugs090
UGII_BASE_DIR: /soft/usr/ugs090
UGII_ROOT_DIR: /soft/usr/ugs090/bin/
UGS_LICENSE_SERVER: 28000@licsrv
1UG is very sensitive about the environment variables.  You should NOT have '/' at the end of UGII_BASE_DIR path and you MUST have '/' at the end of UGII_ROOT_DIR path.
3It is advisable to specify %UGII_BASE_DIR%\UGII\ at the beginning of the PATH environment variable to avoid DLL version conflicts.
2Only UG versions prior to 9.0 utilize the UGS_LICENSE_SERVER variable, while newer versions utilize SPLM_LICENSE_SERVER.
See Also:
UG Reader Support
