The VDAFS reader uses the vdafs_reader.ini file with the following available options:
@BreakAngle
Value |
Description |
double |
A negative value (default) indicates that the curves are being split at C1 discontinuities. A positive value indicates that curves are being split at G1 discontinuities with an angle greater than the given value (expressed in radians). |
@CleanupTol
Value |
Description |
double |
A negative value (default) means to use the auto cleanup tolerance. A value greater than the calculated auto cleanup tolerance means to use that specific tolerance. Refer to the CAD Cleanup Tolerance section. |
@DoNotMergeEdges
Value |
Description |
on |
Preserve the original geometry edges, instead of merging them together during the import cleanup phase. |
off |
Merge edges together during the import cleanup phase (default). |
@ImportForVisualizationOnly
Value |
Description |
on |
Import the model for visualization purposes only. This skips many of the import steps (cleanup, stitching, solid creation, and so on) to provide a faster import. The resulting model may not be suitable for other uses. |
off |
Import the model in the normal fashion (default). |
@ImportFreeCurves
Value |
Description |
on |
Import free curves (wireframe entities) into the model (default). |
off |
Do not import free curves. |
@ImportFreePoints
Value |
Description |
on |
Import free points into the model (default). |
off |
Do not import free points. |
@MetadataPrefix
Value |
Description |
string |
The string is prefixed to all metadata names. No prefix is used by default. See CAD Metadata Naming for more details. |
@ParameterTolerance
Value |
Description |
Any positive real number. |
The reader considers this tolerance as the parametric tolerance used to process the CAD data. The default value is 1.00E-06. |
@Planes
Value |
Description |
on |
Treat each surface as found in the CAD file (planes/NURBS). |
off |
Convert planes into NURBS surfaces. |
preferred |
Convert NURBS surfaces to planes if they are within the object space tolerance of being planar (default). |
@ScaleFactor
Value |
Description |
double |
Defines the model scaling factor during import. Default is 1.0. |
@StraightPolynomials
Value |
Description |
on |
Treat each polynomial segment as a straight line segment. This is necessary for reading some VDAFS files, COMPUTERVISION CADDS 4X in particular. |
off |
Treat each polynomial as found in the CAD file (default). |
@TagsAsMetadata
Value |
Description |
on |
Read tags of supported entities as metadata (default). TAG |
off |
Do not read tags. |
@Tolerance
Value |
Description |
The reader considers this tolerance as the object space tolerance used to process the CAD data. The default value is 0.01. |
