This section describes what is needed for enabling and displaying HyperView in stereoscopic 3D. HyperView was tested using NVIDIA and AMD hardware and recommendations below are also located at www.nvidia.com/object/3d-vision-main.html or www.amd.com/us/products/technologies/amd-hd3d/Pages/hd3d.aspx
Requirements
| 1. | A display capable of displaying 120Hz or higher refresh rates |
| a. | If using a regular display monitor then an IR emitter and corresponding glasses, like the NVIDIA 3D vision kit, maybe required in order to view 3D images. |
| 2. | A compatible 3D TV using AMD HD3D or the NVIDIA 3DTV Play software drivers or NVIDIA’s 3D Vision Kit |
A complete list of TVs and cards can be found here:
www.nvidia.com/object/3d-vision-displays.html
www.nvidia.com/object/3d-vision-geforce-cards.html
www.nvidia.com/object/quadro_pro_graphics_boards.html
A complete list of TVs can be seen here http://www.nvidia.com/object/3d-vision-displays.html
| 3. | A driver version of 197.03 or newer (recommend the 320.00 driver, or newer) for NVIDIA cards and 9.003.3.3 or higher for AMD cards should be used. |
| NOTE: | In order to work with a 3DTV, the software from NVIDIA called “3DTV Play” will need to be installed. It comes with the 3D vision kit or can be purchased separately. More information can be found here: http://www.nvidia.com/object/3dtv-play-overview.html |
| 4. | Minimum Operating System requirements and hardware from NVIDIA and AMD: |
| a. | Microsoft Windows Vista or 7 (64-bit) |
| b. | Intel Core 2 Duo or AMD Athlon X2 CPU or higher |
| c. | 1GB or system memory (2GB recommended) |
