Introduction to HyperWorks
Executing Translators or Tools
Command
Options
Descriptions
amfbuilder
Launch AMF Builder to convert AVI files or a collection of image files to AMF movie files, which can be read by HyperView.
Note: The AMF Builder is only available for Windows PC.
batchassembler
The Batch Assembler builds a finite element assembly using HyperMesh without user interaction.  Details are documented in  the Data Manager Batch Assembler section.
cad2h3d
Translates any HyperMesh supported CAD file into an H3D (.h3d) file.
dads_graph
Motion External Reader to convert DADS formatted output to Altair std. format
fatigueprep
Translate h3d flexbody file to .fes file
feko_help
Launch FEKO Help
feko_updater
Launch FEKO command line updater
feko_updater_gui
Launch FEKO updater in GUI Mode
fil2mrf
Translate abaqus result fil (.fil) to Altair multibody result file (.mrf)  for animation in HyperView, and/or Altair binary file (.abf) for plotting in HyperGraph, and/or tabulated ascii file (.tab).
flexprep
-<unit_option_list >
-METER
-SECOND
etc.
Convert NASTRAN punch files, via ADAMS DMAP alters, to an Altair H3D file.
Translate ADAMS MNF files to an Altair H3D file.  Converts an Altair H3D file to an ADAMS MTX file.
help
Launch HyperWorks online Help
hgadams
Reads an ADAMS .req file into HyperGraph.  Converts an ADAMS .req file to an Altair .abf file
hgares
Translate ADAMS ASCII files (.res) to Altair binary files (.abf).
hgmrf
Reads an Altair .mrf file into HyperGraph 2D.
Converts an Altair .mrf file to an Altair .abf file
hgreq
-f
Specifies a file containing the number of requests in file.req to be translated.
Translate ADAMS request files (.req) to Altair binary files (.abf).
hgtrans
-a
Quick translation option that translates all results to an ABF file without a config file.
-h
Displays the help.
-c
Config file name.
-o
Output file (ABF).
-z
Enables result compression using standard file compression.
Translates HyperGraph plot and time history files to a compressed and platform independent ABF file.
hmabaqus
-u
Lists all the options
Translate Abaqus .fil result file to HyperMesh binary result file format.
hmansys
-u
Translate ansys .rst result file to HyperMesh binary result file format
hmasl
ASL translator to HyperMesh binary results
hmcmold
-u
Translate cmold result file to HyperMesh binary result file format
hmdytran
-u
Translate DYTRAN result file to HyperMesh result file format
hmgenres
 -d - Displacements
 -s - Stresses
 -ds - d and s (default off)
 -off - Displacement Offset (default off)
 -lf - Long Float Files (default off)
 -lid - Long Id Files (default off)
-disk - Translation is performed on disk (default off).
-size - Number of entities (10000 default)
 -file - Scratch file name (default off)
Hmresdmp reads a binary HyperMesh results file and displays it as ASCII
hmmflow
-u
Translate MOLDFLOW result file to HyperMesh result file format
hmmadymo
-u
Translate MADYMO result file to HyperMesh result file format
hmmovie
Translate MOVIEBYU ASCII results to HyperMesh Binary Results
hmnast
-u
Translate NASTRAN punch file to HyperMesh result file format
hmnastf06
-u
Translate NASTRAN f06 file to HyperMesh result file format
hmnasto2
-u
Translate NASTRAN OP2 file to HyperMesh result file format
hmnastopt
-u
Translate NASTRAN opt file to HyperMesh result file format
hmnike
-u
Translate LS-NIKE3D binary results files to HyperMesh binary results files
hmpam
-u
Translate PAM-CRASH result file to HyperMesh result file format
hmpatran
-u
Translate information from a PATRAN binary results file to HyperMesh result file format (limited support)
hmresdmp
Translates a HyperMesh binary .res file to ASCII data
hvtrans
-a
Quick translation option that translates all results to an H3D file without a config file.
-h
Displays the help.
-c
Config file name.
-o
Output file (H3D).
-z
-zh
Enables result compression using high file compression.
Translates a solver result file to an H3D file.
mvg
-m
Merges the following components into a single real component image named merged_name.
-c
Extracts the specified component from the input file.
-f
Reads the component list from the specified file.
-a
Specifies angle for edge detection.
A graphics translator that extracts components from an input file and creates a MotionView graphics file.
