Manufacturing Solutions
Delete Panel
Delete Panel
Delete Panel
User Profiles:
Incremental_RADIOSS
Incremental_LS-DYNA
RADIOSS One Step
Die Module
Use the Delete panel to delete data from a model database, preview and delete empty collectors, and preview and delete unused property collectors, material collectors, or curves. You can also delete an entire model database, if you wish to start with a clean database.
Panel Usage
Empty Entities
The following entities can be empty:
•component collectors
•load collectors
•system collectors
•sets
•groups
•assemblies
•vector collectors
•output blocks
•load steps
•beam section collectors
•control volumes for OptiStruct
•multibodies
Unused Entities
The following entities can be unused:
•systems
•properties
•curves
•materials
Any curve that is used only by a plot is considered to be unused.  A curve is considered to be used if it is attached to something, such as a load or material.
Entity-Specific Options
If choose surfs, you can also choose to delete any solids and/or elements associated with the surfaces. When deleting associated solids  edges will be removed where the deleted surface was connected, if possible, regardless of whether there was a solid or not.
If you choose connectors, you can also choose whether to delete only the connectors, or the connectors and their realized FE.
If you choose solids, you can also choose to delete any bounding surfaces and/or elements associated with the solids.
Subpanels and Inputs
There are no subpanels on the Delete panel. All inputs and command buttons are located on the main panel.
Panel Inputs
Input
Action
entity selector
Use this button to select the entity to delete.
When you select elems, click the switch to change the selection mode.
elems
Select individual elements, or select all of the elements contained by a component or on a surface.
faces_edges_entities
faces
Select all of the elements on 2D and 3D faces.
If there are discontinuities on a 2D face, then only the elements inbetween the discontinuities will be selected.
faces_edges_faces
2D faces ext
Select all of the elements on a 2D face that contain discontinuities.
faces_edges_2d_faces_ext
face angle / individual selection
Face angle
The face angle is the angle between the normal of facets that share an element edge. A facet can either be a shell element itself, or one of the faces of a solid element. The normal of triangular facets is that of the plane defined three corner vertices. Whereas, the normal of quadrilateral facets is calculated by taking the cross-product between its two diagonals. This special treatment for quadrilaterals is because a warped shape does not lie completely on a plane.
Only available when the entity selector is set to elems and the selection mode is set to faces or 2d faces ext.
Individual Selection
Select individual elements on a face or select individual free/shared edges of elements.
Only available when the entity selector is set to elems and the selection mode is set to faces.
Command Buttons
The following action buttons appear:
Button
Action
delete entity
Deletes the selected entity.
reject
Rejects the selection; nothing is deleted.
delete model
Deletes the entire model regardless of the current selection.
preview empty
Displays any empty collectors.
preview unused
Displays unused collectors.
return
Exits the panel.
See also
Alphabetical List of Panels
Alphabetical List of HyperMesh Panels
