Manufacturing Solutions
Color Panel
Color Panel
Color Panel
User Profiles:
Incremental_RADIOSS
Incremental_LS-DYNA
RADIOSS One Step
Die Module
Use the Color panel to change the color attributes of a collector.  Color can only be specified by collector.  For example, if a collector is designated to be blue, the lines and elements belonging to that collector are also blue.
Only entities that are valid for the entity selector can be colored (but black is not a valid color for collectors).  All other entities derive their color from their parent collector.
Subpanels and Inputs
There are no subpanels on the Color panel. All inputs are located on the main panel.
Panel Inputs
Input
Action
entity selector
Select collectors for translation.
color
Click to open a pop-up color menu.  Click a color to select it.
set color
Click to change the selected collector to the selected color.
auto color
Click to automatically re-color most collectors in the model.  This applies to collectors currently using colors 9 through 16 (gray), as well as colors 1 (black) and 2 (white).  You do not have to select collectors first.
See also
Alphabetical List of Panels
Alphabetical List of HyperMesh Panels
