Manufacturing Solutions
Line Drag Panel
Line Drag Panel
Previous topic Next topic Expand/collapse all hidden text
Line Drag Panel
User Profiles:
Die Module
Use the Line Drag panel to create a two- or three-dimensional surface and/or mesh or elements by dragging nodes, lines, or elements along another line.  An example of its use is illustrated in the design of an exhaust pipe.  You can create a cross section of the pipe and drag it along the curved line which represents the pipe.  Another example of its use is in the design of a window frame.  A cross section of the molding can be created and dragged along the complex curves of the frame.
Subpanels and Inputs
The Line Drag panel contains the following subpanels and command buttons:
hmtoggle_arrow1Drag Geoms
Use the Drag Geoms subpanel to drag existing geometry such as lines.
HM_Panels_bmp00176
standard_arrow_beforeafter
HM_Panels_bmp00178
Panel Inputs
Input
Action
Drag: node list / line list
Use this collector to pick the nodes or lines that you wish to drag.
HM_Panels_bmp00175
In this illustration, two lines are selected.
Along: line list
Select the guide line along which you want to drag the entities.
HM_Panels_bmp00176
use default vector / specify vector
This toggle determines the direction for the drag.
If you select use default vector, the end of the line is used as the base point and the tangent direction at the end of the line is used as the vector.
If you select specify vector, use the plane and vector collector to select the orientation vector.
Pick a base point, if required.
HM_Panels_bmp00177
(Mesh options switch)
Click the rightmost switch and select the desired mesh and surface option. For information regarding the meshing options, refer to the Automeshing section of the User's Manual.
The orientation vector is used to orient the line being dragged to the tangent of the guide line.
If the orientation vector is not initially pointing in the same direction as the tangent of the guide line, the section will be oriented.  This may result in the section being rotated.  To prevent the section from being rotated, select the orientation vector so that it is along the tangent of the guide line.
Line segments can be used on both of the lines by selecting points on the line.
Surfaces can only be created by dragging a planar line along a guide line.  If the line being dragged is not planar, it is projected to the appropriate plane.  The mesh w/o surf option does not have this limitation, and does not project the line being dragged to a plane.
If line drag, with mesh w/o surf selected, is used before entering the automeshing module, the placement of the displayed nodes for the "along" edges gives only an approximation of where they are actually created when the mesh is generated.  Indeed, the lines themselves are only approximations; if the drag is very complex, they may degenerate into a straight line.  This does not affect the actual mesh.
hmtoggle_arrow1Drag Elems
Use the Drag Elems subpanel to drag existing elements.
HM_Panels_bmp00181
HM_Panels_bmp00182
Panel Inputs
Input
Action
drag: elems
Use this collector to indicate which elements you want to drag.
HM_Panels_bmp00179
along: line list
HM_Panels_bmp00180
Select a base point, if required.
HM_Panels_bmp00181
on drag =
Enter the number of two-dimensional elements to be created along the guide line.
bias style
Use the switch to pick between linear, exponential, or bellcurve bias.  This affects the spacing of the 2D elements created during the drag.
bias intensity =
Use this to set the strength of the biasing effect.  A value of zero indicates no biasing at all.
hmtoggle_arrow1Command Buttons
The following action buttons appear throughout the subpanels:
Button
Action
drag
Perform the drag.
reject
Undo the most recent drag, deleting all geometry or elements created by the drag operation.
return
Exit the panel.
How do I...
expand-green-10Create a surface by dragging lines or nodes along a line
1.Select the drag geoms subpanel.
2.Click the entity selector switch and select nodes or lines as the data type to drag.
3.Pick the nodes or lines you want to drag.
In the illustration, two lines are selected.
HM_Panels_bmp00175
4.Click line list to the right of along: and select the guide line along which you want to drag the entities.
HM_Panels_bmp00176
5.Click the toggle to select use default vector or specify vector:.
HM_Panels_bmp00177
6.Click the rightmost switch and select the desired mesh and surface option.
7.Click drag.
HM_Panels_bmp00178
Undo
Click reject immediately after creating the surface and/or mesh.  To reinstate the rejected entity, click drag again, without changing any of the input data.
expand-green-10Drag elements without creating element biasing
1.Select the drag elems subpanel.
2.Indicate which elements you want to drag:
Pick them on your model.
or
Click elems and choose from the extended entity selection menu.
HM_Panels_bmp00179
3.Click line list and select the guide line along which you want to drag the elements.
HM_Panels_bmp00180
4.Click the toggle to select use default vector or specify vector:.
HM_Panels_bmp00181
5.Click on drag and enter the number of two-dimensional elements to be created along the guide line.
6.Click drag.
HM_Panels_bmp00182
expand-green-10Drag elements with element biasing
2.Indicate the elements you want to drag:
Pick them on the model.
or
HM_Panels_bmp00183
HM_Panels_bmp00184
HM_Panels_bmp00185
5.Click on drag and enter the number of two-dimensional elements to be created along the line acting as the guide.
6.Click the switch following bias style: and select linear, exponential, or bellcurve.
7.Click the data entry field after bias intensity = and enter the desired value.
For more information on the biasing options, refer to the Element Biasing section in the Automatic Mesh Generation chapter of the User’s Manual.
8.Click drag.
HM_Panels_bmp00186
The elements in this illustration were created by using with a negative bias intensity value.
HM_Panels_bmp00187
The elements in this illustration were created without element biasing.
Undo
Click reject immediately after creating the elements.  To reinstate the rejected elements, click drag again, without changing any of the input data.
If the orientation vector is not initially pointing in the same direction as the tangent of the guide line, the section is automatically oriented.  This may result in the section being rotated.  To prevent the section from being rotated, select the orientation vector so that it is along the tangent of the guide line.
A line segment can be used for the guide line by selecting points on the line.
See also
Alphabetical List of Panels
