Manufacturing Solutions
Find Panel
Find Panel
Previous topic Next topic Expand/collapse all hidden text
Find Panel
User Profiles:
Incremental_RADIOSS
Incremental_LS-DYNA
RADIOSS One Step
Die Module
Use the Find panel to locate entities in a database.  You can use the Find Entities subpanel to find individual elements in your model.
When you find entities, you will often want to turn on the IDs, or save them to the user mark. At the very least, when you find a hidden entity, it will be displayed.
The Find Attached subpanel finds entities that are attached to other entities.  For example, after you have selected an element, you may use this function to view the elements that are attached to it, allowing you to move progressively through the model, row by row.  The Find Attached subpanel allows you to find entities that are attached to geometry or FE entities.
The Between subpanel allows you to find entities that are shared by two or more of the selected entities.  For example, you could find nodes that are shared between selected components or surfaces, and so on.
Subpanels and Inputs
The Find panel contains the following subpanels:
hmtoggle_arrow1Find Entities
Panel Inputs
Input
Action
entity selector
Select the data type of the entities to find.
When you select nodes or elems, click the switch to change the selection mode.
nodes
Select individual nodes.
faces_edges_nodes
faces
Select all of the nodes on 2D and 3D faces.
If there are discontinuities on a 2D face, then only the nodes inbetween the discontinuities will be selected.
faces_edges_faces_nodes
2D faces ext
Select all of the nodes on a 2D face that contain discontinuities.
faces_edges_2d_face_ext_nodes
loops
Select all of the nodes on continuous free edges that make a closed loop simultaneously, such as the perimeter of a hole.
Only valid for SHELL elements.
faces_edges_loops_nodes
free edges
Select all of the nodes on free edges of elements.
If there are discontinuities on an edge, then only the nodes on the free edges inbetween the discontinuities will be selected.
faces_edges_free_edges_nodes
free edges ext
Select all of the nodes on free edges of elements that contain discontinuities.
faces_edges_free_edges_ext_nodes
edges
Select all of the nodes on free edges or shared edges (butt joints, L/corner joints, and T-joints) of elements.
If there are discontinuities on an edge, then only the nodes on the edge inbetween the discontinuities will be selected.
faces_edges_edges_nodes
edges ext
Select all of the nodes on free edges or shared edges (butt joints, L/corner joints, and T-joints) of elements that contain discontinuities.
faces_edges_edges_ext_nodes
elems
Select individual elements, or select all of the elements contained by a component or on a surface.
faces_edges_entities
faces
Select all of the elements on 2D and 3D faces.
If there are discontinuities on a 2D face, then only the elements inbetween the discontinuities will be selected.
faces_edges_faces
2D faces ext
Select all of the elements on a 2D face that contain discontinuities.
faces_edges_2d_faces_ext
numbers
Displays the numbers of the entities.
found nodes: on mark / temp nodes
Only displays when nodes is chosen as the entity.
free lines / surf edges
Only displays when lines is chosen as the entity
free edges
Only displays when surf edges is chosen.
shared edges
non-manifold edges
suppressed edges
display: only connector
Only displays when connectors is chosen as the entity.
display: connector and FE
face angle / individual selection
Face angle
The face angle is the angle between the normal of facets that share an element edge. A facet can either be a shell element itself, or one of the faces of a solid element. The normal of triangular facets is that of the plane defined three corner vertices. Whereas, the normal of quadrilateral facets is calculated by taking the cross-product between its two diagonals. This special treatment for quadrilaterals is because a warped shape does not lie completely on a plane.
Only available when the entity selector is set to nodes or elems and the selection mode is set to faces, 2d faces ext, free edges, free edges ext, edges, or edges ext.
Individual Selection
Select individual elements on a face or select individual free/shared edges of elements.
Only available when the entity selector is set to nodes or elems and the selection mode is set to faces, free edges, or edges.
edge angle
Splits edges that belong to a given face.
When the edge angle is 180 degrees, edges are the continuous boundaries of faces. For smaller values, these same boundary edges are split wherever the angle between segments exceeds the specified value. A segment is the edge of a single element.
Only available when the entity selector is set to nodes and the selection mode is set to free edges, free edges ext, edges, or edges ext.
hmtoggle_arrow1Find Attached
Panel Inputs
Input
Action
entity selector
attached to selector
The data type of the entities to which the entities you want to locate are attached.
When you select elems, click the switch to change the selection mode.
elems
faces
faces_edges_faces
2D faces ext
numbers
found nodes: temp nodes/ on mark
Face angle
edge angle
hmtoggle_arrow1Between
Panel Inputs
Input
Action
nodes / connectors
entity selector
The data type of the entities to which the entities you want to locate are between.
elems
faces
faces_edges_faces
2D faces ext
numbers
Face angle
Only available when the entity selector is set to elems and the selection mode is set to faces or 2d faces ext.
Only available when the entity selector is set to elems and the selection mode is set to faces.
How Do I...
expand-green-10Find an entity
1.Select the find entities subpanel.
2.Click the entity selector switch and select the data type of the entities.
3.Indicate which entities you want to find by selecting them on your model, or click the data type and choose from the extended entity selection menu.
4.Select the data type and choose the entities you want to locate.
HM_Panels_bmp00134
5.Activate the numbers check box if you want the numbers of the entities to be displayed.
6.Click the toggle to select on mark or temp nodes.
7.Click find.
HM_Panels_bmp00135
Click save found to place the found entities in the user mark.  These entities can then be accessed from other panels using retrieve in extended entity selection.
When finding connectors, you can choose to display only connectors or both connectors and the FE realization.  When you click save found, only the found connectors are saved in the mark (not the realized FE).
expand-green-10Find entities attached to other entities
1.Select the find attached subpanel.
2.Click the upper switch and select the data type of the entities that you want to locate.
For example, select elems, lines, tags, etc.
3.Click the lower switch to highlight it and select the data type of the entities to which the entities you want to locate are attached.
4.Select the data type and choose the entities.  (In the illustration, a node is selected.)
HM_Panels_bmp00136
6.Click find attached.
HM_Panels_bmp00137
Some combinations of entities such as finding nodes attached to nodes or finding connectors attached to contact surfs, are not valid operations.  In such situations, an error message will be given.
When finding entities attached to other entities, the display of the original entity remains unchanged.  For example, if you are finding elements attached to an element with ID 6 and element 6 was not originally displayed on the graphics area, the find function displays the elements attached to element 6, but does not display element 6 itself.
When you choose to find connectors attached to components, all the connectors that have the selected components as link entities in their definition are found.  It is not the intention to find the connectors that reside in the selected components.  For example, connectors (with IDs 1, 2 and 3) are defined as connecting components named floor and bracket.  These connectors are in a component named welds.  When you find connectors attached to component floor, all three connectors are displayed.  But if you find connectors attached to component welds, none of the above connectors will be displayed (found).
When you choose to find connectors attached to elements (or elements attached to connectors), all the connectors that have the selected elements as link entities in their definition are found.  It is not the intention to find all the connectors that have the selected elements in their FE realization.  For example, a model contains a connector defined as connecting shell element (ID 34) and element (ID 68).  The connector is then realized as a weld element (ID 2156).  When you find elements attached to this connector, elements with IDs 34 and 68 are found (not the weld element 2156).  This function behaves in a similar fashion for finding connectors attached to elements.
expand-green-10Find the nodes that are shared by the selected components
1.Select the between subpanel.
3.Click the lower switch and select the data type of the entities for which you want to find the shared entities.
HM_Panels_bmp00138
4.Click find.
HM_Panels_bmp00139
5.To save the entities that are found to the user mark:
•Click save found.
When you choose to find connectors between components, connectors that have all selected components as link entities in their definition are found.  It is not the intention to find the connectors that reside in the selected components.  The behavior for finding connectors between surfs, elems, and tags is similar.
expand-green-10Remove entity numbers from the display
Click numbers off.
See also
Alphabetical List of Panels
