Manufacturing Solutions
Run Analysis (RADIOSS One Step)
Previous topic Next topic Expand/collapse all hidden text
The Run Analysis panel allows you to submit and monitor analysis runs.  Select Run Analysis from the Setup menu to display this panel.
Once you have setup the model parameters, you can submit the job for analysis.
run_analysis_panel_onestep
Before submitting the job, ensure that:
•You have specified a material for each component
•You have applied thickness and friction values
•No internal edges exist in the model
•The model is in the stamped position (see Note below)
If these parameters are not set correctly, an error message is displayed.
Note:It is assumed that the stamping direction is parallel to the z-axis.  Orient your model consistently.
How do I...
expand-green-10Submit an analysis run
1.Double-click project = and select the project name.
The project name may be different from the file name.
2.Click title = and enter a title.
3.Click run analysis.
The analysis is processed.
4.Click View Output to view a summary of the run.
5.Click Load Results to display the analysis results.
See also
Alphabetical List of  Panels
