User Profiles:
Incremental_RADIOSS
Incremental_LS-DYNA
RADIOSS One Step
Die Module
The Modify Addendum panel allows you to modify parametrically the addendum geometry created in the Addendum panel. Essentially, it provides you with highly efficient tools to change the rib parameters by either dragging at the rib ends or modifying the geometry or location of the binder. While updating the geometry, it regenerates the geometry around the modified rib and merges it smoothly with the neighboring surfaces.
How do I…
| 1. | Select the drag rib end subpanel. |
| 2. | Select the rib you want to modify. |
| 3. | Select the method to modify the addendum. |
| • | modify plus of last subsection will extend the plus tangent to the part |
| • | modify last wall angle will change the angle of the last draw wall |
| 4. | Click get handle to obtain the handle at the rib end to drag. |
| 6. | Select the handle on the graphics area by using the left mouse click. |
| 7. | Move it to the desired location on the binder surface. |
| 8. | Click update to pass the rib end through the handle and modify the addendum surface to pass through the modified rib section. |
| 9. | Click reject to get back to the original configuration. |
| 10. | Click clear handle to removed the existing handle. |
| The above process may be applied to multiple ribs simultaneously. |
| 1. | Select the edit rib params subpanel. |
| 3. | Click edit rib to open the Rib Editor. |
| 4. | Modify the rib parameters. |
| 5. | Click update to change the rib and modify the addendum surface to pass through the new modified section. |
| 6. | Click reject to get back to the original configuration. |
| 7. | Click clear handle to remove the existing handle. |
| 8. | Click reject to get back to the original configuration. |
| 1. | Select the edit binder subpanel. |
Numerous options are available to modify the binder by editing the cross-sections or translate and rotate. For a detailed explanation, see the topic on the Binder panel.
| 5. | Click update to modify the addendum surface to pass through the modified binder. |
| 1. | Select the cast rib subpanel. |
| 3. | Click the candidate rib. |
This will change the candidate rib to the geometry of the model rib and also modify the addendum surface to pass through the modified rib.
| 5. | Click reject to get back to the original configuration. |
| 1. | Select the add rib subpanel. |
| 2. | Select the rib to copy. |
| 3. | Click on a node at which the selected rib needs to be copied. |
| This will copy the rib and also modify the addendum surface to pass through the new rib. |
| 1. | Select the delete rib subpanel. |
| 2. | Select the rib(s) to delete. |
| This will delete the rib(s) and also modify the addendum surface to pass through the existing ribs. |
| 4. | Click reject to get back to the original configuration. |
See also
Alphabetical List of Panels
