Manufacturing Solutions
Quick Edit panel
Quick Edit panel
Quick Edit panel
User Profiles:
Incremental_RADIOSS
Incremental_LS-DYNA
RADIOSS One Step
Die Module
Use the Quick Edit panel to split surfaces and washers, change the category (shared, free, and so on) of edges, create or delete surfaces and points, project points, and trim fillets.  This can be utilized with the option to force the immediate re-meshing of surfaces after a topology change (set in the Meshing options panel accessible from the Preferences menu's meshing options sub-menu; the setting is labeled topology revision on that panel.)
Some of the entity selectors can be used in conjunction with the rectangular selection box (<shift> +click-and drag the mouse to select multiple entities).  These entity selectors include a "(s)" in the label--for example, line(s) rather than line.  In some cases, you can use either the right or left mouse button with the selection box to accomplish different tasks, as described for each the control group below.
This panel combines many tools for rapid editing of model geometry.
Subpanels and Inputs
There are no subpanels on the Quick Edit panel.
Panel Input
Input
Action
split surf-node
This control group has two different behaviors which are set by selecting the toggle at the end of the second collector.
•If set to node-node, selecting two locations (nodes) splits the surface.  Additional splits require you to pick a new pair of nodes.
•If set to node-nodes, selecting the second node location also splits the surface, but additional node selections will continue to split surfaces based upon the previous selections: the second node selected becomes the new first node, so clicking another node counts as the second node selection. Click the middle mouse button to finish this string of node selections and return the highlight to the first node collector.
split surf-line
This control group splits a surface from a selected node to a selected line, such that the resulting split is perpendicular to the line chosen.  This function has two different behaviors which are set by selecting the toggle at the end of the second collector.
•If set to node-line, selecting a node and a line splits the surface.  Additional splits require you to pick a new pair of nodes.
•If set to node-lines, selecting the second line still splits the surface, but additional line selections continue to split surfaces based upon the split point (node) on the previously-chosen line.  Click the middle mouse button to finish this string of node selections and return the highlight to the node selector.
washer split
Use these controls to create a washer seated on a hole in your model.  First specify an offset to determine the width of the washer, and then highlight the line selector and pick the line(s) to which you wish to add washers of that thickness.
unsplit surf
Use this lines selector to pick and remove a split-line from a surface, making it a single continuous surface again.  You can select multiple entities by using the shift-click selection box.
toggle edge
With this lines selector highlighted:
•Left-click a free edge (red) to make it shared (green), or a shared edge to make it suppressed (blue).
•Right-click a suppressed edge to make it shared, or a shared edge to make it free.
In either case, the edge must meet the criteria for the type of edge you wish to change it to.  For example, toggling a free edge to a shared edge requires the presence of a similar edge within the distance you specify in the tolerance field.
filler surf
With this lines selector active, pick a closed-loop line (a hole) in your model to create a surface that fills the hole.  Only free edges (red) are valid, and they convert to shared edges (green) after creating the filler surface.
delete surf
Highlight this surfs selector, then pick a surface in your model to delete that surface.
adjust/set density
Allows you to interactively change mesh node density along selected edges when at least one of connected surfaces is meshed. When mesh settings specify remeshing after a topology change, changing the mesh density along an edge immediately remeshes the surface.
To adjust density, use the first line(s) collector. Left-click a surface edge to increment the element density by one, or right-click to decrement the element density by one.
•Adjust density can be applied to multiple edges at once by utilizing the shift-click rectangular selection box with either the left (increment) or right (decrement) mouse button.
To set density, use the second line(s) collector. This allows you to select a line with the correct target density using the left mouse button, then apply this density to additional edges using the right mouse button.
•The numeric label appearing after the left mouse button click indicates the target element density.
•Set density can be applied to multiple edges at once by utilizing the shift-click rectangular selection box with the right mouse button.
replace points
Use these controls to move points from their current locations to the locations of other points, effectively combining them.  Use the moved selector to pick the point you wish to move (or use the shift-click selection box to pick multiple points).  Use the retain selector to specify the point that you wish the moved point to combine with.
add/remove point
Highlight this points selector, and then left-click a node, line, or surface in your model to add new point to the model geometry.  Alternately, right-click an existing point to remove it.
You can use the shift-click rectangular selection box (with the right mouse button in this case, not the left) to remove any points within the selection box.
add point on line
To add multiple points to a line, highlight the line(s) selector, specify the # of pts that you wish to add to that line, and then pick the desired line in your model.  The specified number of points appear at evenly-spaced intervals along the line’s length, between the existing end-points of the line.
release points
Highlight this points selector and then pick points in your model to disassociate those points from their lines, surfaces, and so on thus converting them to free points.
project points
Use these controls to move free points to existing surfaces or lines.  Use the toggle to affect whether this happens singly, or as a chain of actions:
•If set to point(s)-line, then the selected points are moved to the selected line, and the operation ends.  To perform additional projections you must select a new set of points and a new line.
•If set to point(s)-lines, then you can add the selected points to series of lines by clicking each desired line in series. Click the middle mouse button to finish this string of line selections.
Note:This feature only works for a maximum distance tolerance of 10, and a maximum feature angle of 30.  However, these limitations do not apply to the project subpanel of the Point Edit panel.
trim-intersect
Use these two node selectors to choose nodes at each end of a fillet.  HyperMesh then removes the fillet, extending the lines until they meet in a corner instead of a fillet.
Undo
In all cases, the reject button provides a way to immediately undo the most recent edit.
Note:Once you perform another edit, or leave the Quick Edit panel, you will no longer be able to undo the previous edit.
In all cases except for toggle edge, add/remove point(s), and adjust/set density, the right mouse button steps backward one step: either rejecting the last action performed, or in the case of functions that use two entity selectors and in which the second selector is active, clearing the second selector and highlighting the first selector again.
See also
Edge Edit panel
Surface Edit panel
Nodes panel
Node Edit panel
Lines panel
An Alphabetical List of Panels
HM-2000: Import and Repair CAD
