The Advanced button in the Streamlines Settings area of the Streamlines panel opens the Advanced Options dialog. Here you can change a number of parameters which control how the streamlines are generated. These settings will affect all rakes.
Integration method |
Runge-Kutta2: Second order Runge-Kutta integration scheme. |
Integration step length |
Element-fraction: Fraction of local element size to be used as the step length for integration. |
Decimation criteria (used to reduce the memory consumption) |
Decimation: Activate this checkbox to enable streamline decimation. Max break angle: Maximum break angle (in degrees) between consecutive streamline segments. Max speed variation: Maximum variation of speed (in percentage of the average vector field over the domain) between consecutive streamline segments. Max line segment length: Maximum streamline segment length in percentage of bounding box size. |
Termination criteria |
Max length: Maximum length of a single streamline. Max number of steps: Maximum number of integration steps for a single streamline. Terminate speed: Terminates the streamline integration if the speed is smaller than the percentage of the average vector (velocity) field over the domain. |
Delete Streamlines |
Deletes any existing streamlines for the selected rakes from the model. |
