Engineering Solutions
BOM Comparison Tool Failed Records Section
When a BOM file is loaded, the tool checks for the validity of each standard attribute in a record (a record corresponds to one line of info in the BOM file).
The tool considers the following five terms as standard attributes:
Part Name
Part ID
Material
Material ID
Gauge
If at least one attribute is missing or repetitive, the whole record is considered invalid and will be stored out-of-sight. Click the Show failed menu item or corresponding button in the control section to see the failed records. This opens a Failed records table as shown below.
BOM_FailedRecords
You have the option to edit each of those failed records to make them valid and move them to the BOM display table using the Move button.
See Also:
BOM Comparison Tool GUI
BOM Comparison Tool
QA/Model Utility Menu
