Engineering Solutions
Configuring the Solver Browser
Previous topic Next topic Expand/collapse all hidden text
In the Local View Options dialog you can configure display and behavior of the Solver browser. Open this dialog by right-clicking in the browser and selecting Configure Browser from context menu.
Global options includes options that are common across all user interfaces; Local options includes solver specific options.
hmtoggle_plus1greyLocal Options
Show empty folders.  Display every entity type supported by the solver in the browser.
Maximum number of items.  Change the maximum number of items to display in the browser.
Show/Hide/IsolateOnly Attached.  When performing Show/Hide/Isolate Only on loads, load collectors, load steps, groups, and contact surfaces, attached elements will also be included in the operation in the graphics area. This can be observed if the elements are currently masked or the elements belonging to the component's display state is off.
Show/Hide/Isolate Include files with XRef.  When performing Show/Hide/Isolate on Include files, the contents in the Include files will also be included in the operation. If you turn this option off, Show/Hide/Isolate will only affect components and other entities that have graphics (vectors, systems, plies, laminates, loads) in the Include file.
Hide Attached.  When performing Hide on loads, load collectors, load steps, groups, and contact surfaces, attached elements will also be masked in the graphics area. This could be observed if the elements are currently displayed.
Delete association.  Open the Delete component(s) and unique associations dialog when Delete Advanced is selected from the context menu. When this box is checked off, the Delete component(s) and unique associations dialog does not open when Delete Advanced is selected from the context menu, and the entities uniquely related to the selected component are automatically deleted. Only available for components in the LS-DYNA user profile.
hmtoggle_plus1greyGlobal Options
Autofit.  Fit the selected entities to the graphics area whether using the context menu or the Selector, Show/Hide, or Isolate functionality to control the display.
Stripe background.  Turn the white and gray stripe background in the browser on. When off, the browser background is white.
