When this import option is selected, Engineering Solutions will:
• | Create a component based on the HMCOMP NAME card |
• | Move elements into component based on the HMMOVE card |
• | Assign properties based on the HMDPRP card |
When HMCOMP NAME does not exist in the imported deck, and there is a one to one ratio between elements and properties (2D and 3D properties), Engineering Solutions will create one component and move all the elements into this one component. Properties will be assigned to the element.
When HMCOMP NAME does not exist in the imported deck, and there are multiple elements with the same property, Engineering Solutions will create a component for every property, move all the elements that have a property into the associated component, and create one component for all elements that do not have a property. The property will be assigned to the component.
